Will using a gold hdmi lead as opposed to scart improve picture
Will using a gold hdmi lead as opposed to scart lead improve picture quality noticeably ?have a sky + hd box but am currently using scart lead rather than hdmi lead. TV is a panasonic viera tx32lmd70a.
Plug the SCART to TV in the bottom SCART not the top one!
If you just want a SCART to SCART make certain you get the highest quality ones you can find.
There is an OPTICAL output for the high quality sound. You can connect this via an OPTICAL lead to either a Surround Sound unit if you have one or direct to the TV. Again if it has an OPITICAL lead.
If using make certain the output it is switched on at both ends. You will see a red light if the TV is outputting it, with it unconnected to the VCR.
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
You don't need a scart lead for your ps3 if you have a HD television. All ypu need is the HDMI cable (which is not included with a new PS3 but you can get very cheap from Ebay- don't bother with 'gold plated' or other 'high quality' cables as they are all the same output quality). The HDMI carries audio and video to your HD television, but you can use a scart lead for audio if and the HDMI for video if you want to use external speakers. The ps2 scart cable also works for the ps3 if you don't have a HD television. (note: a HD television is highly recommended because the quality is a hundred times better). Mine is a Samsung HD monitor which you can buy fairly cheaply.
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
If your console has an hdmi port, which sits just above the av port on the back of the console, you can use an hdmi cable this will improve the quality of the picture.
hope this helps.
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
A lot depends on the quality of the cables you are using. If you are using the leads which came with your cable (scart leads) theyare not string enough you need to purchase gold platted leads in insulation...good manufacturers are belkin/ pure av. this goes for hdmi cables too. it is all well and good buying a good tv but you need the superior cables to use it
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
