Neff W5340X0 Washer Logo
Posted on Apr 13, 2010
Washing machine not draining the water
Error code E06, weve drained all the water and attemped the wash again same error code appeared, checked the filter on front of washer, nothing stuck in there, attempted wash again and same error code keeps appearing, not sure what to do
tsounos
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Apr 13, 2010
tsounos
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
8783
Points
85
The weater pump is bad replace....
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1421
Points
We had the same code E06 and found that the powder was causing too much soap suds, the machine was trying to drain foam and not water. We changed from powder to the small liquid capsules and the problem is now solved.
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
3helpful
2answers
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
It is FO 2 its happpend twice no papper work for it?
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
1helpful
I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin...
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
3answers
WDI12C Machine Will Not Drain - Error Code E06
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
1helpful
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Top Neff Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Eric
ADMIN Eric
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
