Samsung S1050 Digital Camera Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i watch video from Samsung s1050 in my computer?
Anonymous
Level 3:
Genius:
  • Master 1,035 Answers
  • Posted on Apr 13, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1035
Questions
0
Helped
400301
Points
3026
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. how can i watch video from Samsung s1050 in my - ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT butthow can i watch video from Samsung s1050 in my - 0e83d9c.pngrc="/uploads/images/0e83d9c.png" alt="0e83d9c.png" class="h_mi" />
  • Anonymous Apr 13, 2010
    To play the movie clip on your computer.
    Install the camera software Digimax Master: You can download, view, edit and save your digital images and movie clips clip with this software. This software is only compatible with Windows.
    Starting PC mode
    •If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
    •In this mode, you can download stored images to your PC through the USB cable.
    ■ Camera settings for connection
    1. Turn on the camera
    2. Connect the camera and computer with the supplied USB cable.
    3. Turn on the computer. The camera and computer are connected.
    4. External device selection menu will display on the LCD monitor.
    5. Select the [Computer] by pressing the Up / Down button and press the OK button.
    ■ You can download, view, edit and save your images and movies with this software. This software is only compatible with Windows.
    ■ To start the program, click [Start → Programs → Samsung → Digimax Master → Digimax Master].
    1. Connect the camera to your PC.
    2. A window for downloading images will display after connecting the camera to your PC.
    - To download the captured images, select the [Select All] button.
    - Select desired folder in the window and click the [Select All] button. You can save captured images and selected folder.
    - If you click the [Cancel] button, downloading will be cancelled.
    3. Click [Next >] button.
    ● Downloading images
3helpful
My Samsung S1050 camera is reading card locked on the display how do I unlock it??????????????
Remove the memory card, there is a very small slide switch on the side. Slide it to the unlocked position.
1helpful
My samsung s1050 keeps locking up intermitantly. beem stays on.lens freezing.have to re insert batterys over and over to get working. any ideas?
The Samsung S1050 is very battery hungry - make sure you use very fresh new batteries, rechargeable are great - the higher the mAh rating the better. I use Intec rechargeable batteries which are rated at 2900 mAh. If you do use rechargeables, you will have to set the appropriate menu setting for battery type to reflect the type of batteries used.
I cannot download my pictures from my Samsung S1050
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
1helpful
I have a Samsung S1050 Digital Camera and I would like to know how to set the self-timer please? (I do not have the disc or manual, I think one of the kids has eaten them!) Help!!!
Press right on the multiselector (marked with a one-handed clock).
You can download the manual from
http://downloadcenter.samsung.com/content/UM/200802/20080204145832796_S1050_English.pdf
S1050 frozen
Today (2009/11/21) have the same problem with the black model of s1050, sometimes ear the motor running but the lents dont move and the cam still dead.
Source problem : Photos whith ASR+Macro+5xZoom and switch to AUTO+Macro+5xOptical+3xDigital
Look s like shutter is not closing
Yes, it requires removal and strip down to clean the shutter.
Test out the video. That should be ok as it does not use the shutter
Wondows not recognized
go to this link, download and reinstall the drivers, hopefully work for you http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=s1050
Samsung s1050 not compatible with my video editing software
i know i have the same problem and its so annoying and the people at samsung will never like put anything on the internet or i even called and they didnt have a program to work it drives me up the wall
May 22, 2008 • Cameras
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
