Wirlpool AWD60A 6KG dryer and it doesnt dry clothes
Today I bought a Wirlpool AWD60A 6KG dryer and it just seem not to dry the clothes i have put it on 3 time today 2 hours at a time and they are still not dry. Any ideas wot could be the problem?
It is washer/dryer. Which means it will take out all the water from the clothes during spin process but will not completely dry the clothes as done in the other dryers.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
IN FIRST INSTANCE DONT JUST SWITCH OFF APPLIANCE - REMOVE PLUG FROM SOCKET AS WELL.
On rear of dryer their is a panel - under this panel lies the heater assembly and two protectors (TOC'S) it is more than likely that one of these has failed - Test with meter to find which one..
You have a classic air flow obstruction. To prove this phenomenon, remove the vent from the back of the dryer and try drying a load. If issue is resolved, then you must rectify the vent issue. Also, an internal air obstruction is less likely to be the cause, but not knowing how long this installation has been unmaintained, this too should be investigated.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue. Thank you, Dave E. (Illeagle) "Your satisfaction is my personal reward"
