Question about Pentax Photography
Espio 60s, E2 error code, what does this mean?
Posted by s_coghill on
5 Related Answers
Anonymous
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
Anonymous
  • 389 Answers
SOURCE: Getting error code e2 and
U2 this invalid or undue motion scanning device, lamps or copiers panels. It is Necessary to make sure that 2 and 3 mirrors are not bolted screw for transportation, they are found with left side, where the mirrors 2 and 3 stoped . For checking remove glass and try to move the scanning device. Avoid the reason of the stop. If no, search for the fault in sensor, on the left and on the right on движени скарующего device, they can be запылены. opposite event follows to call the service engineer.
Posted on Sep 12, 2009
Anonymous
SOURCE: HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Posted on Jul 21, 2010
Anonymous
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: Fedders air conditioning error code E2
Indoor coil temp defective. Replace it.
Posted on Jan 01, 2011
What does the code E2 mean in a Kenmore Elite washing machine mean
Hi Ryan, an E2 error code is a stuck button on the control panel. Try pressing the buttons slightly off center to see if they free up, if that doesn't clear the error code then the control panel needs to be replaced. Hope that helps.
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
What does E2 mean?
Error Codes mean different things on different machine brands. It is an error message indicating your machine is malfunctioning. Usually your owner's manual will have a list of error codes in the Troubleshooting Section that describes the problem and suggested resolution. If not, then search the internet for your machine's:
Manufacturer + Model + error code E2
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
2helpful
2answers
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
1helpful
Pentax Espio 115 exhibits an H3 error and camera does not work. Sometimes it's a H2 or 1 error. What does this mean.
RE: Pantax ESPIO 115
Dear Sirs,
I bought the Pentax espio 115 Camera in Tokyo and have been well using but it was out of order suddnly .I could find in Lcd panel appeared <H3 mark>and not worked after.
Kindly let us know as quickly as possible what should I do shoot the trouble..??!
Awaiting your kind response.....
Thank you.
Mr.U.S,Yu?South Korea
email:[email protected]
Mar 21, 2008 • Cameras
Photography Logo
Top Pentax Photography Experts
Ekse
Are you a Pentax Photography Expert? Answer questions, earn points and help others
