Question about Archos 5 MP3 Player
Archos 5 not working, will not switch on.
Archos 5 played great and recorded from tv, using the Archos snap on. When I registered Archos 5, on Archos web site, the site recomended to download firmware update, this I did, and also downloaded two plugin packages. Big mistake, as my Archos 5 has not worked since. When charging my Archos 5, through computer using USB cable, the charge light stays on constantly, when I unplug my Archos 5, after approxmately 5 - 6 hours, the chage light still stays on for a few hours then switches off. I assume this is because the battery has gone flat.
Posted by Catherine Smith on
Anonymous
    New Friend:
  • 161 Answers
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Posted on Apr 13, 2010
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
Trying to connect Archs DVR snap on to LCD TV and record
As far as i am aware you cannot record directly from the tv using a dvr snap on to record from the tv you would need the dvr station.
Dec 28, 2009 | Archos 5 Internet Media Tablet
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Copying Video from archos 605 wifi to computer
I think the Archos 605 has a 2gb file limit, so the only option would be to split the avi.
Search on Google for an avi splitter - there are some free ones out there.
May 06, 2009 | Archos 605 WiFi Digital Media Player
Tv program guide will not update when connected through my dvr
The TV Program Guide is actually controlled by a 3rd party.
I registered my Archos at Archos.com when I bought it......I'm not sure how you'd stand with a 2nd hand one.
Basically, the website tells me that I only have 82 days left to my TV Program Guide 'subscription' and if I want it for another year, I have to pay £14.90GBP!
However, I can tell you that the Program Guide is pretty rubbish. All it does is let you record the SAME channel that your TV is showing. It does not record a different channel if you want to watch something else and if the TV is switched off, it doesn't record at all!!
Reading the manuals and the reviews on the Archos website, I was led to believe that it would do all of the above, but when I tried to get help from Archos Support, they basically told me that it doesn't do any of that!!
As much as it p'd me off, that is the only flaw I have found in the Archos and the other things it can do are quite amazing.
Try searching for 'Archos Forum' and check out some of the features - it is a remarkable machine!
Apr 19, 2009 | Archos 605 WiFi Digital Media Player
MININ DV TO ARCHOS
Initially, it would work better if you can provide the specific model numbers of the Sony Mini DV Cam and the Archos. Assuming all things even, most DV cameras have an analog A/V video OUT, in turn some Archos with recording capability have an analog A/V video IN. If this were the case, then it would be a matter of getting the right connectors/plugs + cable and/or adapter/interface.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Archos AV700 Digital Media Player
Archos 405
Hi fiona
I had the same problem as the archos web site is not the easiest to navigate.Have you actualy registered the product yet ?if so once logged in add your device as a product,on my products click on the picture of the 405 and that will take you to the screen for downloading archoslink (software to install the tv guide) and to the subscription page for down loading the tv guide.
How ever i have done all this and although i can download the guide i cannot sync it to my 405 so still unable to record off tv....Email gone to archos so fingers crossed....
Apr 27, 2008 | Archos 405 Digital Media Player
Archos 504 dvr shuts down when I plug it into the tv and there is no sound.
The same thing happens to me. I've noticed that it is on the dvds and vhs recordings (ie, copy protected) that this happens. The other files (downloaded from internet, tv, etc) play fine. I think it has something to do with copy-protection that allows files to be saved to device, but not transmitted out. This allows you to save and view your commercial recordings on the Archos, but not let the program to be sent to a recording device such as a dvd recorder.
Jan 25, 2008 | Archos 504 500870 Digital Media Player
Can't get the dvr working
ARchos is macrovision compliant to prevent copying copyright programs. I think in some cases the recordings are encoded as such and will not play on your tv in those cases. I would fire off a letter to Archos technical support archos.com) and check with them on this.
Nov 20, 2007 | Archos 504 500870 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos 5 MP3 Player Logo
668 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
