Nintendo DS Lite Console Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to check error system date in ds lite? suddenly when i turn it on it became like that. It wroted in red sentences.
Anonymous
Level 2:
  • Expert 37 Answers
  • Posted on Apr 16, 2010
Anonymous
Expert
Level 2:
Answers
37
Questions
0
Helped
225840
Points
181
All you have to do is go into the options and click on the calender. set is back about a year and that should fix it. if u only set it back for 2 days the problem will most likely come back in 2 days
best of luck. by the way i have answered this question to a lot of people
  • Anonymous Apr 16, 2010
    all you have to do is go into the options and click on the calender. set is back about a year and that should fix it. if u only set it back for 2 days the problem will most likely come back in 2 days
    best of luck.
1helpful
I was charging my DS lite when my puppy knocked it off. when I started it up, it said: "system date error! please check NDS System date" What do I do?? Is my r4 broken? ><
Check you Dsi system date and time,this need to be accurate for R4 card to work properly,put that date and time since it was giving that error,wont work with todays date.Also update your system with new and original software.
System date error! please check nds system date.
Sounds the new error that's come up for <a href="http://www.dscardworld.com">R4i SDHC</a> . The new update should fix it or you can rollback your date on your DS.
DS Lite Console: system date error please check nds system date...
Or you can check out a card that never gets a date error. I got an M3i Zero from http://www.dscardworld.com and it's never given me any problems.
4helpful
My ds lite has: "system date error" how do i fix
Let us investigate in this matter and try to resolve it.
Since the 10th of April, 2010, some users of the Nintendo DS and DSi and the R4i SDHC card have experienced an error that stops the DS card / DSi card from being used. The error contains the message “Loading… System date error! Please check NDS system date” when a user turns on their Nintendo DS, Nintendo DS Lite, Nintendo DSi or Nintendo DSi XL console.
The reason of this error seems to be an incompatibility between the actual system date on the Nintendo DS console and the R4i SDHC card. This is possible of the Nintendo DS was played until it lost all power, or if the memory card within the R4i SDHC was formatted incorrectly. It can also be attributed to the date simply being incorrectly calibrated. In some situations, transferring a .SAV file from another Nintendo DS that has a different system date on it, can also trigger the problem. It currently seems to be that the problem only manifested itself after the 10th of April, 2010. While the team behind the R4i SDHC are working on a fix to be a future part of a software update, consumers are advised to go into their Nintendo DS system settings and set the date back until the R4i SDHC card can continue to function as normal. In some cases, setting the date back up to a month is required to temporarily solve the problem.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Until a software solution is found, the R4i SDHC team would suggest consumers keep their dates wound back. To hear the latest about what solutions, both temporary and permanent, please visit the blog on http://www.dscardworld.com where solutions will be tested before presented to the public.
Hope that works.
Regards,
Anirban Mazumdar
4helpful
3answers
When turning nintendo ds lite on it comes up with this message System date error! Please check NDS system date.
it is just an eol (End Of Live) in the software of your ds card.
Plug out your ds and remove your r4 card.
Plug on your ds and change the date to 2009.
Plug out your ds and insert your r4 cart.
Plug on your ds and you can play again.
Now there wil be new software on the internet who is an update on the old software, so if you want to renew your software ist there on the net.
2helpful
2answers
Erm, the problem is' it dosen't appear to have
Hi ya
Remove the R4i card. Go to your settings and turn the date back by about a year.
turn off, put card back in and it should work,
2helpful
Ds date and system
You have to update de firmware of your R4 card (I just tested the new version V1.16b and the bug is fixed). For the time being you can change back the date before the 14th of April and you can play directly.
When turning on my nintendo ds with the R4 card inserted the top screen shows red writting stating ''System date error! Please check NDS system date.'' what does this mean?
think you have to go on to site and download new upgrade for it to work.....waiting on hubby to check out and try. r4i-sdhc.com
On using R4 card in NDS message says System date error. Please check NDS system date
Think you need to go to r4i-sdhc.com to download upgrade for system which became active on 14th april!! Good luck
My ds lite R4 card has a message when switched on saying System date error! Please check NDS system date. How can I fix this?
Hey,
A System Date Error is a problem with the firmware. There is more information at the blog here as well as a link to the system date error fix! I think you can avoid a lot of problems like that by getting an Acekard . It's worked perfectly for me for months now :).
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
