Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Vacuum smells like something is burning
When I turn on the vacuum, it starts to smell like something is burning.
Posted by apetersen07 on
Gerry Harvey
    Genius:
  • Bissell Master
  • 1,481 Answers
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Posted on Apr 13, 2010
5 Related Answers
Vac Belts
Vac Belts
  • 701 Answers
SOURCE: when i vacuum it smells and so i turn it off. the
The belt is probably worn and slipping, that is why it smells. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Posted on Nov 17, 2009
debbily
Debra V
  • 101 Answers
SOURCE: belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Posted on Oct 16, 2007
Anonymous
  • 3 Answers
SOURCE: My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Posted on Mar 15, 2009
Vac Belts
Vac Belts
  • 701 Answers
SOURCE: Burning smell
The smell is from the stretch belt. If It has been two years I'm sure you need to change the belt, that belt should be changed at least every 6 months. You can get the belt for this model here:
http://www.vacbelts.com/hoover-40201160-belt.htm
Posted on Oct 22, 2009
Testimonial: "Thank you for your response. That is exactly what was wrong with the vacuum."
Vac Belts
Vac Belts
  • 701 Answers
SOURCE: Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Posted on Oct 29, 2009
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
When I turned on the vacuum it started to smell
the vacuum is either shorting or the motor or brush assembly is rubbing something.
Jul 31, 2009 | Rainbow Vacuums
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt is burning?
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
1,013 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
