Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a DVR from Comcast hooked to the tv; what else is needed to view in HD. It is a Philips 60" projection HDTV (model 60pp9202) and how can I get a replacement owner's manual?
Posted by stratusprizm on
Jose Garcia
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U need to ask ur cable provider what kine of service u have , not all cable boxes are hd , for ur owner manual just google , some may have this for free
Posted on Apr 13, 2010
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
HDTV
yes your model is HD compatable
Need screen for Philips hd tv
New is expense..Do you want a used?.......Look here for new: vancevaldwing.com Question? [email protected]
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
2answers
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
