How do I hook up my surround sound system thru my stereo and tv
connecting your surround sound system is not complicated.things you may need:OLDER STEREO SURROUND SOUND:analog red, white, and yellow cable connectorsHDMIaudio fiber opticsif you bought your stuff new from electronics store,then it would be easier.all you need is HDMI cables (mostly)depending where your inputs and outputs go, you must know the rule. OUT-TO-IN. that means if you are using a cable box, dvd, bluray, playstation, or xbox. everything in these electronic devices are OUT. then connect them to the IN ports of your surround sound. at the back of your surround sound there will be connections saying IN-dvd, IN-dvr etc. connect your OUT DEVICES.
NOTE: YOU MUST KNOW WHAT ARE YOUR CONNECTIONS, LIKE DVD-IN OR DVR-IN CU'Z YOU WILL USE YOUR REMOTE TO CHOSE WHICH CONNECTIONS YOU WANT TO USE.
now from your surround sound to your tv.the same ruleout to in of your tv. You should look for HDMI port that is saying OUT. you will connect your HDMI cable from there connecting to your IN of your tv. remember which port you plugged the HDMI cable as you will switch to that particular input. it will say at the back of your tv in-1, in-2, in-3 or as much as the manufacturer want to have in there product.
connecting your speakers.you must remember the color code.if you chose red as positive, all the red wire must be positive.colour may be different but same idea. if you have sub-woofer it will be an analog cable you will only use single cable. At the back of your surround sound there's a connection saying sub-woofer out.
now selecting your inputs.turn on your tv and stereo.newer tvs and stereos are smart they can configure there system which is turned on.
anyways if you will do it manually, you must select from the remote what is the connected input. (input 1, input 2 etc.) if you found the right input, do the players (dvr, cable box, dvd, bluray, playstation, xbox etc) turn them all on and select from your stereo remote control.note all the inputs you selected.
