Motorola Mobility W376 Cell Phone Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but nothing seems to work. Is this a problem with my phone or my charger?
Anonymous
Level 2:
Sniper:
  • Expert 107 Answers
  • Posted on Apr 13, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
107
Questions
0
Helped
26087
Points
352
I think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargerMy phone is fairly new ( a few months old) and for - moz-screenshot.png
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
2helpful
2answers
Samsung s duos wont charge
even i have got the same problem. Its two weeks old and is not getting charged. I.ve tried both the regular charger and the usb cable to charge it. Guess will have to take it to the service station.
My battery wont charge but it says its charging. When I unplug the cord 3 times itll go up by 1%
Have you tried replacing the battery? It sounds like the charger circuit is attempting to charge the battery and the battery is not accepting the charge.
4helpful
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 • Cell Phones
My Razr v3 won't turn on and it's only 2 months old. the battery was fully charged in another phone. I've tried holding the on button down, plugging in the charger and replacing the battery but the phone...
Well you seem to have done the hard bit.Either charger or battery you`ve tested.
Just had one thought,How long was the battery out of the phone?
So put the phone in a warm room for 2-3 hrs.As condensation can form in the phone. Firstly remove the battery and check there`s no moisture anywhere.
The last solution I can think of is to try a battery in the phone ,plug the charger in and try charging for 3 hours. It can take time for the graphics to appear.
Well after it not being the battery,charger it will be the phone. So take it back to your retailer and ask for a replacement.
Hope i`ve helped!
Phone has been idle for a few months. Will not turn on or charge.
Hi have you tried to charge the phone What hapens ?
1. could be that the charger is not outputing the proper current an longer may need to purchase a new charger for the Cell Phone.
2 try to charge the battery in a different phone if possible maybe a friend has the same brand otherwise only one option left buy a new battery and chage it if it works then problem is fairly simmple
the old battery has reached the end of its life and will not charge !
7helpful
3answers
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Charge complete but phone/display does not work
it is technical problem pleas go to sarvice center and replace u r handset cause it is in warrenty dont try to open it, or change with new battery
Aug 20, 2007 • LG VX3100
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
