Question about Samsung HP-P4271 42 in. HD-Ready Plasma Television
Only shows channels 3-23 and then only shows a few hd channels
When first got tv it was showing all the channels perfectly but now it will only show the regular channels 3-23 and then only a few hd channels
Posted by skkherring1 on
Anonymous
  • 304 Answers
Are you using a Cable Card? Have you tried the Channel search function in the user menu. Select Channel set up and do a channel search.
Posted on Apr 16, 2010
Panasonic dmr xw385
Have you got the tv aerial connected into the dvd?
2answers
Manual for kenmore model 51569104
Go to Searspartsdirect.com with your model number. You should be able to find a parts diagram there
Norcent model LT-2725 TV to ps3?
Check the video out settings of PS3.
2answers
Tv does not show hd picture it only shows normal tv picture
The tv alone will not show HD picture. You will need a set top box to watch HD programs and channels. You need what is called a Digital decoder box. You may want to purchase a PVR.
because your VCR will not record Digital video or audio.
My Hd channels are saying complete signal loss then later they are available again, then complete loss again. Can switch to non hd channels but want the Hd. What do you suggest
Hi edhayes27 my name is Mike Houston of DISH Network Executive Office. This posting in FixYa shows you have the 311 receiver; this receiver will only show SD channels. We do have the VIP 211 which will show in HD and SD channels. If possible can you verify the model number of your receiver, which indicates you
TV HAS LINES ON THE SCREEN
sounds like a scaler problem.
hd bypasses the scaler, any non hd will be bad, try other stuff like dvd and video games. if its consistent, you need a new digital main pcb
if not, let me know i can help
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
1helpful
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Samsung HP-P4271 42 in. HD-Ready Plasma Television Logo
Ekse
Demonic-2011
Demonic-2011
