Question about Dometic RM2652 Refrigerator
I have a Dometic DM2652 refrigerator and the check light comes on when I hook up to electric & cut off the gas.
Posted by alvenia_rees on
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: trying to purchase a heating element for a Dometic Dm2652
Try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673. there not a dealer just a service department, they might be able to help.
Posted on Feb 16, 2010
Anonymous
SOURCE: i have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Posted on Aug 18, 2010
Anonymous
  • 157 Answers
SOURCE: My dometic DM2652 works on gas & electric but
First thing to do would be to check the electric heating element with an ohmmeter
Posted on Jun 22, 2011
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: I have a Dometic DM2652. The refrigerator light bulb is missing. what size bulb do I need to get
I have a parts manual and it says on page 5 of the PDF location 43 in photo of the manual that 43 2007290006 A B Lamp, 10W, 12VDC. You need to scroll to the next page and line 43 is part number 2007290006 is the Lamp, 10 watt and 12 Volts DC Here is a link to the parts Manual=> Refrigerator_Parts_List.pdf Now that does not tell much about the socket but you may see that it is common. Or ask one of the major sites like GasRefrigeration.net Hope that is helpful, Thanks, Sea Breeze11_21_2011_7_26_21_am.jpg
Posted on Nov 21, 2011
My dometic refrigerator DM2652 is cooling in gas mode but will not switch to AC. The unit is getting power but the "auto" light will not come on.
That fridge has 2 elements. A 12v and mains 240v/120v. Sounds like the mains element or the fuse has blown. The fuse box is in behind the fridge at the bottom. Follow the power cord to the box. There should be 3 fuses. Check them all. Using a multimeter, check the readings of both elements. Google " Dometic Service manual DM2652 pdf" and page 11 should help you.
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
8helpful
I have a dometic dm2652 rv fridge. its new and is
2helpful
2answers
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Jay Finke
Jay Finke
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
