maytag quiet series 200 water is leaking from the bottom. the hoses are fine. can you help.maytag quiet series 200 water is leaking from the bottom. the hoses are fine. can you help.
You can't post conmments that contain an email address.
Hi.
Sounds like a leaky inlet valve. Sometimes they don't seal off completely or the membrane inside it could be torn. Best to replace the whole valve.
Regards Sam
This is a very common reason for a leaking dishwasher especially
if this was a new installation. The framing in a dishwasher is made up
of mostly thin sheet metal, so if it is not sitting flat and level
things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look
for rips and distortion of the seal. If it is ripped or distorted you
will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy
to check, remove the front panel and carefully inspect around the seal
for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends
up leaking. Check this connection ( there is usually some sort of
adaptor between the valve and supply hose) for leaks. Check the
connection on the back of the water inlet valve also. Ocassionaly a
water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need
to check the housings for leaks along with all the connections. Some
dishwashers have a seal that leaks down into the pump . This is easy and
inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch.
To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from
opening a heavy load of dishes on the door. Occassionaly a broken spring
or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
