SOURCE: 3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
SOURCE: Old technology Stiffy drive replacement
what a very interesting question! :) you can find support, parts and service here: (German language) http://www.maschinensucher.de/bruecken/Kunststoffverarbeitungsmaschinen.html (English translation) http://www.maschinensucher.de/bruecken/Kunststoffverarbeitungsmaschinen.html i myself need more info to help you fully! please post here more info on the types of D outputs and inputs, as these are either really old, ANSII or maybe even analogue! i do know that you can connect this to a parallel port on a computer and from their store the DATA however you want. good luck.
SOURCE: No disk message or your disk is not formatted you want to format it , Yes Or No
Sound incompatibility issue, probably your device will only work with Win98
SOURCE: The Z1D CITIZEN floppy drive on this computer cannot read
some floppy can read and some floppy cant read
it means that ur floppy drive reads the information which they originally save it from citizen floppy drives. Floppy drives like citizen if u use in any place u can use the citizen floppy drive any where
SOURCE: Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
