Question about Dell 1702FP UltraSharp 17" TFT LCD Flatscreen Monitor
There is a black line and see through pink bar on my monitor
There is a black line running vertically in the middle of my screen and theres also a see through pink bar on the left side of my monitor. im not sure whether its my monitor or my video card causing this issue.. please help me!
    New Friend:
  • 55 Answers
Disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Posted on Apr 17, 2010
6ya staff
SOURCE:
My Aspire 5670 screen is dead.
Update the video drives, if that doesn't work replace the vga cable. If that doesn't work try it on another monitor.
Jan 19, 2013 | Computers & Internet
Sony Bravia KDL52XBR4 with ~3 inch bars going vertically down the screen. One bar is pink (opaque) and is around the middle of the screen on the left side. Also, 3 inches to the left of this pink line is...
You are correct, it can be the T-CON or the LCD panel itself, there is no 100% solution to this, but swapping the T-CON first, may be try reseating the ribbon cables between the LCD panel and the T-CON first (not easy to get to and must be real carefull!).
Learn about SONY T-CON/LCD panel troubleshooting guide here:
Download PDF: http://www.mediafire.com/?zzjygannjty
Failed SONY: http://s807.photobucket.com/albums/yy352/budm/SONY/
Failed T-CON/LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 11, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
The bottom of my screen is black and blue starting solid on bottom and sides for about an inch give or take then gradually becomes spotted balck with blue background and has a pink line running vertically...
I suggest either trying another monitor on the computer with this problem or plugging the monitor into another computer.
That will isolate the fault to either the computer or the monitor.
Nov 15, 2017 | ViewSonic VX910 19" LCD Monitor
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
BLACK LINE on screen and see-through Pink Bar!
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Line on the screen
I have a black vertical line about 3/4" wide with thin border pink, green and blue lines. My cursor runs behind this line but I am unable to find a way to make it just go away?
May 09, 2009 | Computers & Internet
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Computers & Internet Logo
163 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
