I use windows movie maker with the dazzle. I select the option "record from video device" and then select the dazzle and record my video. But! After I record the video i go back to watch it and the audio is desynched and the voices of the people are changed. Please anyone know how to fix this I cant figure out what wrong with it to save my life.
Very common problem with their software - they try to force you to purchase better stuff. For starters, try Corell Video Studio to see if it works better - it has a free 30 day trial period. I use it, and find that it is among the better packages to use.
Open your Instant DVD recorder and then go ahead and select Go Direct to the advance mode. ONe window showing out there. Select your Dazzle dvc device and then click on options. Now click on video input and then click VHS input. On video input choose video composite if your video cable is yellow, red,white cable. Then click okay. Make sure that your cable is direct connect to the video out put of your camcorder. If still the same thing uninstall your video device driver. Video device is located under control panel>system>hardware>sound video and games controller then right click on pinnacle video and audio device uninstall. Restart the computer.
Did you mean you are recording video and audio using your Television set? I'm afraid that dazzle is not design to used if for capturing or even capturing using Windows Movie maker. Because dazzle device is design to used for Pinnacle Studio program and Instant DVD recorder program only, It is not supported to used for both of them. That is the reason why there is no Picture while recording.
you need to connect rca jacks or the mini jacks to the anolog side of your sound card and the 9 pin connector will use for video to capture aslo if your using windows movie maker you need to select the imput type and mpeg 2 or mpeg3.
Make sure that the connections is properly connected. Just to inform you that if your connection is S-video you will not be getting sound.
If your using the Instant DVD Recorder please click option in the step number one then locate for the audio input make sure that the dazzle dvc is selected.
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source: you should select the options:
Video standard NTSC (Because this is the default in our region) Video composite - if you are using RCA (red, yellow and white cables) S-video - if you are using the cable with several pins in it.
2. Select Burner You should select the options: Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc. TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option, this means that your DVD drive is not able to burn a DVD)
3. Select menus It must be NO
4. Recording select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
A lot of times Dazzle provides a calibration program for video and sound. See if you can run that.
There usually is a seperate audio capture control. If you go to your sound mixer and check the recording settings, is the audio capture from the Dazzle selected?
