Light on my remote Hunter ceiling fan works but the fan does not
I would suggest buying a new fan at the price of the replacement part for your existing Hunter Fan. Ceiling Fan Direction have fans at lesser price compare to other online retailers.
http://www.ceilingfandirection.com/
CeilingFanDirection
Maybe the capacitor on the fan are damaged
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
