We are using a Dell 2300 projector. The Power cord is plugged in and the blue ended cord connecting the laptop and the projector are connected and on. Nothing is showing up on the screen. Says it is looking for a signal.Usually I will see the desktop from my computer. Any suggestions
While it's looking for signal press Ctrl+f4 or Ctrl+f6 or Ctrl+f7 .
please rate .
Check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
