Sharp R-1872 Convection/Microwave Oven Logo
Question about Sharp R-1872 Convection/Microwave Oven
Microwave part is not working
The microwave part of oven has stopped working but everything else works fine
Fred Yearian
  • 5,603 Answers
There are several possible causes... none of which are user serviceable. Take unit to a shop for repair.
Possible problems include door switch, Magnetron, rectifier, control relay, etc.
Posted on Apr 12, 2010
Testimonial: "thanks for reply , confirmed that it was not user repairable."
1helpful
I have a combination oven/microwave but the microwave is not working? what should I do?
It is most likely one of three things, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. I recommend a professional to assess, chances are cheaper to replace microwave oven.
My Microwave stopped heating today but everything else works fine. Any idea what the problem might be? Thanks.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Vent fan has stopped working. the keypad says vent fan off. when pressing help, it says press this pad. nothing happens.
A low tech solution worked for me.
I too was getting the "Vent Fan Off" message, and despite the fact that everything else worked fine with the microwave, I turned the breaker off and back on from my electrical panel. The fan works fine now.
My GE microwave just stopped heating the food. Everything else is working fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
dghjd
1helpful
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
2helpful
The Microwave stopped heating
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
