Hi,Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera.Formatting Memory card**you should always format a new memory card or one from which you wish to erase all images and other data.** Please note that formatting a memory card erases all data, including protected images and other file types.1. (Set up) Menu [Format] 2. Select [OK] and press FUNC SET button.Low Level format, recommended by cannon Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Your camera was made before 4GB SDHC card format came out. Sorry, but a Powershot A610 can only work with 2GB or less standard SD cards. Fortunately, these are very inexpensive these days. If your local store doesn't carry them, then here's some from Amazon.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
chjeck On the memory card there is a little slider that locks or unlocks the card, someone can't erase the card accidentaly. Just look on the card and move the slider to the unlock position.that will unlock the card.hope this helps
