Question about Yahoo Messenger
How can i add friends to my yahoo messenger - Yahoo Messenger
Posted by tunde2010rea on
raileymae
    New Friend:
    Problem Solver:
  • 14 Answers
From the yahoo messenger window, click "add contact", type in the person's email or username then click next. Send then the invitation.
Posted on Mar 27, 2012
Anonymous
    New Friend:
  • 52 Answers
Well follow the steps given below .....
In the Yahoo! Messenger window, click the Add button. (With the Windows version, you can also click the Messenger menu and then select Add a Friend/Group.)
  • Step 1. Enter your friend's exact Yahoo! ID or alias name. Your friend must have a Yahoo! ID in order for you to add them to your list. Important: If your friend does not have Yahoo! ID or Yahoo! Messenger yet, make sure to send them an invitation and download instructions.
  • Step 2: Select the group to which you want the friend to be added. If you want to create a new group, just type the name in the space provided. Groups help you keep track of friends (e.g, work friends, chat friends, etc.) separately. Note: Group names cannot contain spaces or special characters.
  • Step 3: Choose whether you want to use your main Yahoo! ID or one of your aliases (profiles) to add your friend. Your friend will only see the ID or alias that you choose, and not any of the others that you might have. Remember that you may need to close the Add dialog box and reopen it to see your new Yahoo! aliases.
  • Step 4: Send your friend a message to appear along with the notice that you've added them.
Note: When you add a friend to your list, the friend is automatically notified and given the option to add you in return. If the friend adds you in return, you are notified.
good luck...:-)
Posted on Apr 12, 2010
5 Related Answers
Anonymous
  • 830 Answers
SOURCE: Friend list disappeared
Make sure that you have the most up-to-date messenger which can be downloaded here. Sounds like an incompatibility issue between your messenger and your friends.
http://messenger.yahoo.com/
Posted on May 09, 2009
Anonymous
SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
Posted on Sep 27, 2009
Anonymous
SOURCE: when I add my friend in Yahoo messenger I found
This can be solved, when your friends accept your invitation.
Posted on Mar 07, 2010
Anonymous
  • 88 Answers
SOURCE: login to yahoo messenger
you have to download Yahoo Messenger from here.
Install and follow instructions to sign up.
Cheers,
Mike
Leave rate if I helped you, thanks!
Posted on May 08, 2010
Anonymous
  • 74 Answers
SOURCE: Add Rocketmail id in Yahoo Messenger
You'll need to use the entire rocketmail address, so it'd be something like "[email protected]" instead of just "yourname".
Posted on Jun 05, 2010
Cant add friends on mesenger, freezes.
Install latest yahoo messenger. - if you need assistance getting your computer back on track. Feel free to contact TechieNow:)
Aug 05, 2012 | Yahoo Messenger
How can I open new yahoo messenger ID to talk my friends,I have a yahoo email..
if you have a yahoo email. you just need to install the yahoo messenger on your computer then login with your email ID and password. you will be logged in to your yahoo messenger.
to talk to your friends add them if you dont have any contacts in your list.
then start talking to your friends.
enjoy!!!!
Jul 06, 2011 | Yahoo Messenger
I dont know how to add more friends
Hi Concrenionel,
Please find the below steps to add the more friends in the Yahoo messenger,
Step 1: Login into the Yahoo Messenger
Step 2: Click on + Sign
Step 3: Now enter your Friends Email address
Step 4: Click on Next
Step 5: Click on Finish
Thanks for contacting Fixya
Regards,
Aysaam
Apr 02, 2011 | Yahoo Messenger
How to add in yahoo masenger
Hi, in the Yahoo! Messenger window, click the Add button. (With the Windows version, you can also click the Messenger menu and then select Add a Friend/Group.)
Step 1. Enter your friend's exact Yahoo! ID or alias name. Your friend must have a Yahoo! ID in order for you to add them to your list. Important: If your friend does not have Yahoo! ID or Yahoo! Messenger yet, make sure to send them an invitation and download instructions. Click here to invite a friend and send instructions.
Step 3: Choose whether you want to use your main Yahoo! ID or one of your aliases (profiles) to add your friend. Your friend will only see the ID or alias that you choose, and not any of the others that you might have. To create additional aliases (profiles) for your account, click here. Remember that you may need to close the Add dialog box and reopen it to see your new Yahoo! aliases.
Dec 01, 2010 | Valley Welding Tools
How can i chat in yahoo messenger
After opening the messenger program you will see the main messenger box. click on theAdd button . You will now be presented with three options asking how you would like to add your friend, By Yahoo! ID, By Email Address or Search for a friend.
By Yahoo ID is the default way to add a friend. click the Next button. You will now see the Add a frienddialogue box. A person's Yahoo ID ís the first part of their Yahoo email address add a friend with the yahoo ID . You can create different groups for your friends, for example you could have one group for family members and one group for work colleagues, enter the name of the group you want to add this friend to a group. Leave your identity as it is .
next The Message to Friend box allows you to add a small message to let them know you have added them. When you have filled in all the information simply click the Finish button, you will then be told that a message has been sent to the person with that Yahoo ID asking permission for you to add them as your friend. It also asks you if you would like to enter any additional information about your friend, for instance a nickname, if you do click the Yes button, otherwise click No.
Now you will see the friend in your friends list on the main messenger screen
to chat to this friend when your friend is online and available the face will be brighter and smiling and the YahooID will be in bold letters.
simply double click on their Yahoo ID in your friends list, this will open the instant message box to send your message either press the Enter key or click on the send button.
Sep 07, 2010 | Yahoo Messenger
Plz tell me how can i chat with yahoo messenger
First you install yahoo messenger in your pc..download from internet -
-If you have yahoo ID then log in from yahoo messenger
-Add friends email ID's in your yahoo messenger..- Click on -Contact - Add a Contact -fillup email ID. & add email ID.
-If you want go to chat room just click on Messenger option - go to Yahoo! chat - Joint Room - And select any one room which you like.- Chat with anywhere - anyone.
Aug 14, 2010 | Yahoo Messenger
Add frinds to yahoomessenger
To add more friends to Yahoo Messenger:
- After opening and signing in to Yahoo messenger, press Control, Shift, and A
John
Jun 26, 2010 | Yahoo Messenger
Want to enter a e mail id
Hi!
If you are already sign in to yahoo messenger and want to add your friends so you can all chat together.. here is what you need to do:
1. On your yahoo messenger, click the "Contacts" menu.
2. Select Add contact
3. An "Add to Mesenger list" window will appear.
4. Enter the email address of your friend in the box (example:[email protected])
5. Click next
6. Choose the group for your friend (example: Friends)
7. Click change if you want to change your name, the way you want them to see on their ym.
8. Click next and finish.
9. You will be waiting for approval of your request if your friends will accept you on their ym..
That is the step to add your friends on your ym. I hope you can get friends as many as you want.
Much appreciated if you could rate this help. thanks
May 21, 2010 | Yahoo Messenger
May 09, 2009 | Yahoo Messenger
Friends' yahoo messenger ID blocked.Can't add it to my msgr list!
Feb 05, 2009 | Yahoo Messenger
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
Mike
Abhinandan  Patil
Abhinandan Patil
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
