As an old Outlook user (for over a decade). I ever met similar error with my Outlook PST files before and got it solved with this Outlook PST repair software, the software extracts & restores those inaccessible Outlook items in a new .pst file and enables complete Outlook data recovery. If you want to take the most effective way, then try that program. Hope it helps too with your case.
That means your .pst file is corrupt. and you can use Scnpst.exe located in drive:\Program Files\Microsoft Office\OFFICE12, to repair it. this is the procedure here.
Regards
In order to repair your outlook you are required to do the following :-
The Inbox Repair tool (Scanpst.exe) is designed to help repair problems that are associated with personal folder (.pst) files. The Inbox Repair tool is included on the first Microsoft Office CD-ROM.
The Inbox Repair tool is automatically installed with all English-language Microsoft Outlook installation options depending on your operating system.
For Microsoft Windows NT and Microsoft Windows 2000:C:\Program Files\Common Files\System\Mapi\1033\NTFor Microsoft Windows 95 and Microsoft Windows 98:C:\Program Files\Common Files\System\Mapi\1033\95The Inbox Repair Tool installs automatically during Microsoft Outlook 2002 and Microsoft Office Outlook 2003 setup. Unlike the Microsoft Office 97 version of the tool, Microsoft Office 2000 does not place the Inbox Repair tool on a menu. To use the Inbox Repair tool, locate one of the folders by using Microsoft Windows Explorer, and then double-click the Scanpst.exe file.
The Scanpst.exe file is typically located in one of the following folders:<disk drive>:\Program Files\Common Files\System\Mapi\1033\<disk drive>:\Program Files\Common Files\System\MSMAPI\1033The Scanpst.exe file for Outlook 2007 is is typically located in the following folder:<disk drive>:\Program Files\Microsoft Office\Office12
To run the Inbox Repair Tool, follow these steps:
If you have tried your options with recovery without any success. Then you are about to loose your data on outlook. Thats the caution. The only option left now is re-installing your office package. Take out your MS office CD/DVD and first try the repair option. If failed then you have to choose instal
I found you stuck since long hence thought of giving the answer. once you lock down to another expert it's not easy for the first one to provide answer. Here's your working solution.
msncon.dll is the MSN Connector that you use to access a paid Hotmail (or MSN) account. download the MSN connector again from MSN and reinstalll it. That will let your outlook work. If you don't wan't msn by any reason then once your outlook starts just create a new account Click Start>Control Panel and run the Mail applet to create a new profile.
This will solve your outlook problem.
Still not working. Now getting this error:
Cannot start Outlook. Cannot open the Outlook window. The set of folders cannot be opened. An unexpected errot has occurred.
MAPI was unable to load the information service msncon.dll. Be sure the service is correctly installed and configured.
I had already reinstleed Outlook 7 when I got the error i sent you in the last email.
