Motorola Mobility MOTOROKR S9 + Bluetooth D650 Stereo Adapter for iPod Headset Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, how can I connect my headset to my laptop ?
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Apr 12, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
21281
Points
145
Since for the sound output connect to the lime green port on the laptop which is for audio out
1helpful
The sound on my laptop does not play back through the headset. How do I get that to happen?
hi,
you need to go to control panel, or right click on the little speaker at the bottom right, select playback peripherals, and then select your usb headset as principal (or system playback)...
cheers,
mich
1helpful
Hi i want to connect Nokia BH 503 bluetooth to dell inpiron laptop, it is detecting the device but could not connect it.
hi my headsent nokia bh- 503 is not connected in mylaptop my laptop want the bluetooth driver peripheral so this driver not found so you give me any web site then i install the drive give my answer
I wish to connect it to my laptop its registering and is connect to the bluetooth but when i make a call on skype it dont work as a mcrophone and speaker
Hi!
If you have paired and connected the headset to your computer, then please do the following:
1. Sign in to Skype and in the TOOLS menu, select OPTIONS...
2. Under AUDIO SETTINGS, select your Bluetooth headset from the MICROPHONE, SPEAKERS and RINGING drop-down list.
Please let me know if it helped.
Best regards
This device Hiadesatoepe 00 does not recognize any phone device .. what is the solution
Hi ahgay1974,
Try 0000 / 1234 / 4321, this works normally the 00 is incomplete the code should be 4 digits,
also make sure that the mobile device you are trying to connect your headset is set to discoverable for the headset to detect the mobile device for proper connection.
This also applies to any other device such as Laptops, Computer so on.....
I hope this helps.
mvincentc
I have a HP USB Digital Stereo Headset connected to my laptop.. and accidentally pulled the cable, after that my headset wont work. how can i fix it.. i tried opening the usb of the headset and looked if...
Hi, Try using another USB connection. Most laptops have 2 or more. If you can borrow somebody elses headset to rule out that the set is or is not working. If that is good, check that USB is still OK. By using another divice. Good luck.
2answers
Hello, i cannot connect my headset (ASUS HS-1000W) with my playstation 3.i ve check it with my laptop and it connected.the flash light is green but not steady.i ve done all the procedure from the manual
If this is a Bluetooth headset, I have found that not all headsets play nice with the PS3. I had to switch to the Sony PS3 headset to get mine to work consistently.
5helpful
3answers
XTM-1200 Drivers not found in laptop i need when i connect bluetooth to detect automatically the drivers for xtm-1200 model bluetooth headset
the answer is easy....buy a bluetooth device.....it will install a new software that is not in ur laptop...and it will work perfectly
I cannot hear any sound in my laptop computer.
Hi brightmensah
Try the following.... *Try to install the audio driver again(if you are getting symbol like this
*If you are not getting this symbol check your speakers by connecting a headset or any audio device to Headset If you are getting sound on headset means this problem is related your speaker connections it's better to contact service center or you can log to www.insidemycomputer.com to change your speaker or it's connections.
Thank you
Connecting Itech clip s35 wireless headset to laptop.
If your laptop has a Bluetooth capability the Windows help section or the Microsoft online help might answer your questions.
2answers
Lost passkey and wanted to connect to my pc laptop
The default pass key for headsets is 4 zeros "0000".
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
