Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
We have 42'' Yard Man riding lawn mower need to how to change oil
We have 42'' yard man 20hp Intek twin ohv briggs & stratton engine we need to know where oil drain plug is to change the oil and oil filter
Anonymous
    New Friend:
  • 10 Answers
It's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
Anonymous
    New Friend:
Have a 46 ins yard man ride on need to know what grade oil it uses
Posted on May 15, 2010
Why won'y my 20hp Craftsman Yard Machine riding mower start?
when changing the belt you might have knocked off a wire to a safety switch
1helpful
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.http://www.ehow.com/info_7929485_briggs-hp-twin-torque-specifications.html
8helpful
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
3helpful
2helpful
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
2helpful
2answers
4helpful
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
16helpful
3answers
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Top Mtd Garden Experts
Dwain Pippen
Morne Olivier
Morne Olivier
dannydoesita
Are you a Mtd Garden Expert? Answer questions, earn points and help others
