Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan
Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Testimonial: "thanx, thats good info. dan"
Yes...
Turn off all power to the unit...
unhook the wires at each end of the element...
use an ohm meter to check for resistance...
if it is open ( no resistance) it is bad...
heatman101
