Hi, I need to know between Sony LBT-ZT4 and Sony LBT-GTZ4i wich one is better. I've already bought a ZT4, after one month it couldn't play and the lights were dimming and ...
I would try going into the menu settings on your receiver to make sure that the subwoofer is turned on or that the volume is turned up. If it is a powered subwoofer you can try hooking the output of a phone or an iPod to the input cable just to test and see if you are getting sound through the subwoofer. If that seems to be working ok then you know the problem lies with the receiver.
If happens you already replace the card and still doing same thing, It only means that the slot for the card is faulty, Its already a motherboard problem. But try updating the BIOS and see if its going to fix the problem, if not its the motherboard that have a problem.
Hi. Make sure the flywheel turns freely and that the capstan pin and pressure roller are clean. If this is OK then it is more than likely that the belt is stretched, dried out or generally worn. These parts only have a certain usable life and are quite cheap to replace.
KSS-213D lens has soldered joint to protect laser diode from static voltages damage when it shipped. You need to unsold laser diode protection joint and then try.
