The washing machine struggled through tthe wash cycle and will not drain to go to the rinse cycle. there is not a front panel to pull off to check the hoses. the machine is still full of water, too heavy to move to lean over and check fromm the bottom.
First remove agitator by taking top of agitator off and putting your hand down the centre of it and unscrewing the wingnut holding the agitator to the main drive shaft. once the nut is loose pull the agitator out and bail the water out by hand using a pot or jug. once the bowl is empty u can look underneath. to the right hand side front of machine u will see a red or black fan that is attached to the pump. turn the fan clockwise and then anti clockwise and hopefully that will unjam the pump. the fan should turn freely. then put machine back on its feet.refit agitator. turn on unit select spin and it should start draining.if it doesnt reply back and i will help u more. please turn off power to unit b4 u work on it. good luck
Testimonial: "Thank you Luisa! I think that did the trick, running an empty load through now to make sure and it has all readdy gone past where it was stuck."
