I have accidentally locked my tv after hitting the "F" button on a Apex remote number K12B-C2. Now I cannot unlock the tv to watch programs. What is the key to unlock the screen so I can viewing tv programs?
If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control http://electronicshelponline.blogspot.com/ Pull up older posts there.
Apex TVs have parental locks that allow you to block certain
programs based on their rating. When this
feature is no longer needed and you want your TV to display all programming no
matter its rating, you must unlock your TV. Unlocking your Apex TV is done
completely from your remote control and does not require any tools. The process
takes less than 5 minutes. • Press the
"Menu" button on the remote control and use the arrow buttons to
scroll down to the "Parental Guide" option, then press the
"Enter" button. Type in the default parental code "6688" if you have not
set your own code. If you have set your own code, type it in. If you set your
own code and forgot it, override it by using "6688." Use the arrow keys to switch the parental lock to "OFF."
This allows all programs to be viewed no matter the rating. Press the
"Exit" button on the remote and start watching all your channels.
Your Apex TV has been locked by anyway. Just try this method to unlock it. Apex TVs have parental locks that allow you to block certain
Answer:According to Apex, you can disable the parental lock using the following information.
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again.
If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
Turn on the TV
With the remote press the F button and the Mute button at the same time. This should bring your TV back to normal mode. from Don "the TV King"
