Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
What is the minimum and maximum air space required for a single 10 nonported.
Posted by brian73178 on
Anonymous
  • 524 Answers
Usually 0.7 to 1.0 CUft
Posted on Apr 11, 2010
How to get the latest Win 10 update from 10586 to 14393 with error "too low memory needs 8G"
To update to Win-10, the system requirements are:
  • The present O/S should be either Win-7 or Win-9 [Licenced version]
  • Minimum 2GHs processor.
  • Minimum 2 GB of Ram
  • Minimum 20GB of free hard disc space partition. (C - partition)
Otherwise, won't go. No need to try.
tip
How to Maximize and Fix the Size of Your Windows Swapfile
<b> <br /></b> Whenever Windows needs more memory than the RAM that you have installed, it uses some of your hard drive space as memory. This memory is referred to as virtual memory, and the space it uses on the hard drive is called the Swapfile.<br /> At the time Microsoft incorporated the Swapfile concept into Windows, hard drive space was at a premium. We were referring to hard drive sizes in megabytes, not in terrabybes as we do today. <br /> According, Microsoft allowed windows to dynamially change the size of the Swapfile (between pre-determined minimum and maximum values) proportional to real-time system memory requirements. This method insured that the "premium" hard drive space would be not be used by the system when there were minimal or no virtual memory requirements.<br /> However, there is some overhead involved with this method of determining Swapfile size as Windows has to continuously allocate and de-allocate hard drive space for use by the Swapfile. Considering the size of today's hard drives, we frequently find 30 or more Gigabytes of hard drive space available (especially on today's home computers). And Swapfile requirements are usually between 1 Mb. And 1 Gb. (1 Gb. = 1,000 Mb.). <br /> Considering the above, if you have an extra 10 or 20 Gb. of available hard drive space, why not set the minimum and maximum values of your Swapfile size to be equal, and relieve Windows of the task of managing your Swapfile size?<br /> To do this, perform the following procedure in Windows XP:<br /> NOTE: This procedure will be somewhat different for other operating systems.<br /> Click on START, and then CONTROL PANEL.<br /> Set contol panel to the "classic mode"<br /> Double click on SYSTEM. And in the Systems Properties box, click on ADVANCED<br /> In the Performance Box click on SETTINGS and then click on ADVANCED<br /> In the virtual memory box click on CHANGE<br /> NOTE: If you have more that 1 drive (volume), all will be listed. Only change the swapfile setting for the volume that presently contains the swapfile.<br /> In the virtual memory dialog box, click on the SWAPFILE DRIVE and click on CUSTOM SIZE.<br /> The initial and maximum sizes of the Swapfile will now be highlighted.<br /> The maximum size should be less than 20% of the available space (listed above the swapfile sizes). If it is not, you may not want to apply this procedure as your hard drive free space is somewhat limited.<br /> To continue, click on the INITIAL SIZE box and change the size to be the same as the size contained in the MAXIMUM SIZE box. Then click on SET and then OK.<br /> Close all dialog boxes and re-boot your computer.<br /> ~~~~~~~~~~~~~~
on Dec 13, 2010 • Computers & Internet
Is There A Required Minimum Or Maximum Factoring Volume?
No, however the greater the higher because higher volume can translate to lower fees for invoice factoring.
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
2helpful
2answers
What do you have to do to become a Wiz in FixYa? I am new and have put in 41 solutions but am still at Master status. When will I be a Wiz and how long until I am a premium expert?
Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required You need to visit the Expert FAQ's section to get answers to this, link is http://www.fixya.com/FAQexp.aspx
but here is an extract:
Ranks are calculated by dividing the total value of the ratings cast on an Expert's Solutions by the Expert's number of rated Solutions. Unrated Solutions, Premium ratings, and Live Chat ratings are not factored into Experts' averages.
Wizz needs 80% or higher ranking, 5 votes minumum and 30 solutions minimum.
The help screens are good so just have a look around and you'll find out lots.
2answers
I download game from internet but it does not satisfied the comp requriement i dont have graphic crad what can i do.........
maybe this would help:
FIFA 10 (Fifa 2010) Minimum Requirements: Proc: 2.4 GHz single-core
RAM: 512 MB RAM for XP / 1 GB RAM for Vista
Video: 128 MB Geforce 6600 or better, Ati Radeon 9800 Pro or better, Support for Shader Model 2.0 or better, DirectX 9.0c
HDD: 4.4 GB or more
Broadband Internet connection required for Installation and online gaming
when the game cannot play because VGA requirement, then u should buy a graphic card that at least appropriate with video minimum requirement.
hope this help.
1helpful
Hi, I've Toshiba Satellite 480CDT laptop installed with windows 98. Can my computer install & support windows XP? I just want this computer to share files with my desktop P4 system which has windows...
These are the recommended hardware requirements in installing windows XP:
  • PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
  • 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
  • 1.5 gigabytes (GB) of available hard disk space*
  • Super VGA (800 x 600) or higher-resolution video adapter and monitor
  • CD-ROM or DVD drive
If your laptop pass all this requirements then you can upgrade your windows 98 to windows xp operating System.
Need to now cpu in my laptop
This is just a rough guide, as it all depends on the the games your looking to play, but this is about normal to get games running without problems :
MINIMUM SYSTEM REQUIREMENTS:
Microsoft(r) Windows(r) XP Service Pack 2, Vista
• 1.8 GHz processor
• 512 MB RAM
• 8 GB available hard drive space
• 128 MB video RAM or greater, with DirectX 9 Vertex Shader / Pixel Shader 2.0 support
• Sound card, speakers or headphones
• 56.6 Kbps Internet connection required.
RECOMMENDED SYSTEM REQUIREMENTS:
3.0 GHz Intel or equivalent AMD processor or better
• 1 GB RAM or better
• 10 GB available hard drive space
• 256 MB video RAM,
with DirectX 9 Vertex Shader / Pixel Shader 2.0 support (Nvidia 6800 or better)
• Internet connection with Cable/DSL speeds
Note: recommended specifications provide optimal experience for single player and up to 4 player/medium size map multiplayer.
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
• Keyboard and Microsoft Mouse or compatible pointing device
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
Top Sony Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
