Try blowing into the reader to clean of any dust. If problem still persists you will have to take it to be repaired by Nintendo engineers (as your DS-Lite reader may be damaged).
I only had that happen once and I looked at the date on the settings and it was set to 2017. I changed it to 2010 and the problem went away.
Games card not being recognised after insertion in slot.
E-bay have a new card reader,which they say needs no soldering. Has anyone had experience of this type of repair?
When i turn my ds one i gey a mesage system date error please check nds system date what do i have to do
SOURCE: nintendo ds lite won't read card
its usually in the menu, change it to ds lite,instead of gameboy.
SOURCE: nintendo ds lite not reading
sounds like your system needs to either be cleaned or a new card slot installed on the unit. there are many shops on fixya if you check the directory that will help you out.
SOURCE: Nintendo DS Lite not reading some games
this is a problem with the pins inside could be dirty or dusty ether way you will need to get a cleaning fluid ie 100% alcohol cleaning fluid us a clean cotton bud inside the slot and use gently as not to damage pins, if the pins are heavy soiled you may need to get a fiberglass tipped pen wich is used to clean up poor contact areas on boards and other electrical circuits
hope this helps if unsure get in touch with nintendo they will prob fix it for you for free go here > http://www.nintendo.com/consumer/repair/
SOURCE: NINTENDO DOESN'T RECOGNISE GAMES IN SLOT
Clean the Ds slot. This happens to me alot, but I just blow into the slot and it works.
SOURCE: how to put games in my memory card at Nintendo DS Lite?
To get an in depth answer seach you tube but in brief.
You will need to download the system files for your type of R4 or flash card you are using, make sure you get the exact model type as they are not interchangeable.
Drag and drop the files to your card you will see either 4 or 5 files. Then make a folder called Games on your micro SD card and load your games into that folder.
It quite involved but the tutorials on you tube go right into it.
