Question about Dell DJ Ditty MP3 Player
How do i put music on the dell dj ditty 512mb
Posted by michealcone2 on
Johny
  • 540 Answers
Connect the device to the PC open "My Computer" and "Computer" then look for the device name or any removable device if you can find it then open it and then copy the music files to that drive and remove it.
Posted on Apr 11, 2010
1 Related Answer
rjnworbnhoj
  • 142 Answers
SOURCE: Dell DJ Ditty
This is a flash memory type player, all you should have to do is plug it in to your computer, select the drive that it is plugged into and it should show all the items on that memory, then select all, and right click to delete. From here you should be able to select different songs from your files and copy them over to that particular drive... See if that helps
Posted on Sep 20, 2008
How do i take off music out of my dell dj ditty mp3
Plug up your dell DJ Ditty MP3 Player
Go to my computer and click on your storage device
You should be able to manually delete what music you want off
Need installation cd for dell dj ditty
buscalo en internet solo ingresando el modelo
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
4helpful
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
2answers
I cant download music
Music Service or from CD
2answers
Computer won't open DJ Ditty
Windows Media Player 11 not compatible with this player.
The device doesn't know if it is a MTP or MSC device - in one of these modes, it will not allow access to the music folder. unfortunately, there is no way to switch between these two modes in the menu settings. Go to Control Panel - Device Manager - find MTP Deivce and update driver.
DJ ditty wont work
Connector bent = replace the player
It won't upload
Make sure the songs are in the correct format
Dell DJ Ditty MP3 Player Logo
Top Dell Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
