I bought a condo...had a Whirlpool 30" freestanding sealed burner gas range w/self cleaning oven...no owners manual...just installation information...
Attempted to do the self cleaning...after 8 minutes...got this error code FSEO...and wont stop beeping...it appears the door doesnt lock shut....please advise on how to clean this oven...thanks for your kind assistance
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
Help yourself to a manual or tech sheet for your stove Kimosabe
Hi
Error code F5-E0 indicates that there is an issue with the
door latch switch assembly; if the switch tests open then the door lock
assembly should be replaced. Hope this helps...please post back for further
assistance.
Daniel
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Wow...thank you for your help...model number is SF377PEGO
Hi, quick question- i have a whirlpool electric and turn it on for self clean and after 10 mins i get F5EO
Can't clean
