Question about GPX Audio Players & Recorders
My gpx MW249s 2gb mp3 player keep saying error everytime i put a new battery in it. But everytime i put a old battery in it, it workS what can i do
    President:
  • 2,923 Answers
Check the voltage and ampere output of the old battery. Make sure that the new battery that you're trying to put in has the same voltage and ampere output.
There's a possibility that some components of your mp3 player requires a specific amount of voltage / ampere out.
However, if you're putting a new battery with the same exact output, then you may need to verify it with the manufacturer. Because, this will be the first time I heard that an electronic device will give an error after replacing the battery.
Thank you and good luck!
Posted on Apr 11, 2010
6ya staff
SOURCE:
Brand new player, just out of the box, think my 8 yr old thru away the instructions etc and cant find the device on my computer when i plugged it into the usb port. Can you help me?
Sure I can help. I think you need to re-install the software for the device then your computer will recognize the unit. Here is a link for the Owners manual: http://www.gpx.com/owners_manuals/MW249S-IB.pdf
I was unable to find a driver for this unit which leads me to believe that GPX has left it up to your computer to recognize the unit. Go to the control panel on the start menu in windows and then click on system then click on the Hardware tab then below you should see a button that says "Device Manager" you will see a drop down of everything your computer has on it look for the devices with errors commonly down toward the bottom you may see your MP3 player has a problem click on it and tell it to update. I sure hope I didn't confuse you here. if you are still having troubles try the software DriverCuremoz-screenshot.pngmoz-screenshot-1.png it has come in handy for me. Thanks, Cody
Sep 26, 2010 | GPX MW249 MP3 Player
Hey Fathitkf how do you update the software of the mw249s cause mines keep having a error message cause i dont know what to do
Hi Domniq
I'm sorry for late response . Yes updating can solve the problem . But I don't recommend updating in your player situation . I recommend you to reset [ restore default factory settings ] your player .
regards .
Apr 04, 2010 | GPX Audio Players & Recorders
Gpx MW249s wont play help
I had the same problem with my GPX mp3 MW249S. I went to the internet and downloaded MP3 Repair Tool 1.5.2 software from www.free-codecs.com and l managed to fix the problem.
Feb 23, 2010 | GPX MW249 MP3 Player
Im having problem wit my mp3 its says error i dont know what to do
just try to update the software of your mp3 .
good luck .
Jan 26, 2010 | GPX MW249 MP3 Player
My sons got a mw249s from their mom for xmas. i have itunes istheir anyway to put itunes music on the player? I tryed drag and drop the device showed the music loaded but cant play it.
You will first need to delete all the music from your MP3 player that you put on it. Use this method to do that: Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER. ---------------------------------------------------------------------------- I tunes is an AAC format, it will not work with your player... You need WMA format to make the songs work on the GPX-MW3836 What you can do is covert the songs from ACC to WMA using a format converter. Then put them in a folder/file and drag and drop them to the player, or download the songs to Windows Media Player after you have converted them and then download them to your player, as Windows Media Player is WMA format. ----------------------------------------------------------------------- You can download a free format converter at this website: www.formatoz.com/ Good Luck, I hope this helped Please rate me, Thanks
Dec 26, 2009 | GPX MW3836 MP3 Player
The GPX drive is not showing
initailly there was a dev. sys config file or something of that nature on the GPX website like a year ago that would allow you to replace and/or access your music and/or the GPX mp3 player, however 2-3 years later they have fixed bugs and put out many other mp3 players so your luck of finding this file is dwindling. try it w/ and w/out batteries and try to go to win explorer as oppsed to "my computer"
Aug 15, 2009 | GPX Audio Players & Recorders
Need Owners Guide
This link shpuld get you to a website where you can download the manual for the MW3847
http://www.gpx.com/owners_manuals/MW3847-IB.pdf
Jan 29, 2009 | GPX MW-3847 MP3 Player
MP3 KEEPS TURNING OFF
Make sure the Hold button on the side, is in the off position!
Nov 12, 2008 | GPX MW3837 MP3 Player
Gpx mp3 charging problem
Make sure hold is not engaged
Last ditch effort:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 12, 2008 | GPX MW3837 MP3 Player
My mp3 is saying erroe
Try deleteing a few and take the batteries out then restart
Apr 11, 2008 | GPX MW3836 MP3 Player
231 people viewed this question
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
