Laing Thermotech Autocirc Undersink Instant Hot Water Circulating System Logo
Posted on Apr 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pump stopped working
I had a leaky angle valve and replaced it. I turned off the water main and did not unplug the Laing right away. When I reconnected everything, the pump did not work again. Suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Aug 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
50761
Points
177
Replace the cartridge
Laing model 330 Pump not working-delay in hot water delivery.In the past,a vibration occurred when cold water running above the pump.Can this be repaired.Power operating to pump. Thanks, mel ross
Question not 100% clear.
1) The pump is not working? Does the pump make a noise? if pump is not working full-time, it can cause delay in arrival.
If pump motor is suspect, and outlet has power, then check override switch located on timer. Set override to Timer, move some of the trippers outward, then manually rotate timer dial until pump turns ON.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
If no noise is detected, or noise stops and starts, or seems strained, or if pump is hot, then pump motor may have burned out.
2) If pump is working, and makes noise like a humming sound, and pump motor is not hot, but hot water is not circulating, then unplug pump so it will not overheat and burn up.
Disassemble the pump and cross-over piece. Clean piping with white vinegar or CLR. Do not soak in CLR or it will damage seals. Rinse parts thoroughly. Reassemble and see if problem is resolved.
If pump is vibrating, then suspects include sediment and/or air inside line, and this can be resolved by cleaning as described. Also install air vent to increase life of pump.
3) Other causes for hot water delay at faucet are crossover.
Crossover can be caused by bad single-handled faucet cartridge, and/or by clogged-or-failed check valve on cross-over piece on grundfos.
This type of problem lets cold water enter hot line, and causes delay in arrival of hot water. Clean-or-replace the grundfos cross-over piece, and replace bad faucet cartridge.
Open following link for testing instructions:
http://waterheatertimer.org/Crossover.html
Resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/pdf/Troubleshoot-recirculation.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
There is water constantly draining through the drain valve.
Grab a cap from the hardware store to stop it on the cheap. If it it is a brass drain valve you may be able to get away with draining the tank and replacing the small washer inside. Replacing the drain valve will be the ultimate solution.
Turn off the power on and electric or shut the gas valve to its off position.
Turn the water supply off above the tank or at the house main.
Connect a garden hose to the drain and open it all the way.
Open the safety valve on the top or side of the water heater to allow air in the tank so it will drain faster.
Unscrew the old drain valve with a pipe wrench.
Wrap plumber's teflon tape clockwise around the threads of the new drain valve and screw it into the tank by hand.
Tighten the valve with your pipe wrench until it is facing down at a 45 degree angle.
Close the safety valve.
Turn the water back on.
Open a faucet or two in the hows to let the air out of the tank while it is filling.
Turn the power or gas back on ONLY after the water heater it filled with water.
Punp ACT 303-BTW was working fine. Got some water leak under sing. Disconnected the pum fron electricity, dryed good and when plug it in had a "POP" sound and lightning fron under the timer. It kept...
if you had a "pop" and lightning from the timer....
the water got into the electronics.
its time to replace.
getting hot.... was the cartridge either spinning dry, or spinning but not able to move water, did you have a valve off somewhere?
you might call laing or one of their distributors and see if its under warrantee.
where are you located, I can probably help you find a distributor.
Top Laing Thermotech Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Laing Thermotech Water Heater Expert? Answer questions, earn points and help others
