Question about Marantz SR-5000
Try to reset the memory circuits, the info on them may be corrupted, try this:
1 disconnect the plug from the AC line supply
2 wait 10 minutes then, reconnect the plug to the AC
outlet
3 try to operate the equipment.
now.. if above does not work you may have to contact the manufacturer as
the issue could be related with the internal circuitry.
good luck!
Posted on Apr 11, 2010
You might not have to reset it, try checking ur fuses, it could have tripped
the circuit when the power went out.
Normaly that's what happens unless
it was a direct contact then, u might wanna go get another receiver, and
what i mean by direct contact, i mean like directly plugged into the
wall socket.
I hope that helps.
Cheers.
My Marantz SR5200 powered off and won't turn back on. I believe there is a two or three button reset but I don't know what that is. The revious solution Fixya gave me was a solution for someone else and doesn't pertain to me.
