Question about Gaggia Evolution Espresso Machine
Gaggia Evolution is overheating
My Gaggia Evolution is about a year old. Recently it appears to be overheating. Coffee comes out with little crema, and seems ''grainy-like''. It runs so hot I can steam the milk without switching the steam switch on!
I descaled the machine several times thinking it had something to do with it. It did not help...
Any ideas?
Thanks!
Tzachi
    President:
  • 1,618 Answers
Check the thermostat on the side of the boiler, that might be damaged.
Posted on Apr 12, 2010
6ya staff
SOURCE:
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
My gaggia evolution leaks water while making coffee .It appears to be coming from inside the machine and leaks everywhere.I have disassembled the machine but i still can 't see where the water is coming...
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
Oct 22, 2009 | Gaggia Evolution Espresso Machine
Bits in my coffee
Hi
If you are using pre-ground and you have ground it for espresso, that too fine and that is why you are getting specks. It should be ground to the size of sugar granules.
Jun 28, 2009 | Gaggia Syncrony Espresso Machine
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
No crema on short black
Make sure the coffee is a fine grade...place holder in machine for 6 mins before filling with coffee and ensure the filter holes are clear and dry.
Oct 20, 2008 | Gaggia Classic Espresso Machine
Crema attachment
It is optional, if your coffee is fresh, you would not need the attachment. If your coffee isn;t the freshest, the attachment comes in handy to create the crema affect
Aug 20, 2008 | Gaggia Carezza Espresso Machine
No crema
Check with the manufacturer Gaggia FIXYA has no information on this topic
Nov 28, 2017 | Gaggia Espresso Espresso Machine
Gaggia Evolution Espresso Machine Logo
390 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
