Question about Miele W310 Front Load Washer
My miele novotronic w310 has a mouldy smell, I have tried cleaning the folds in the rubber seal, what could it be?
  • 447 Answers
Have you tried running the machine, NO clothes, on hot with just bleach?
Posted on Apr 11, 2010
Miele Novotronic w310 washing machine - won't spin and flash 'rinse' on the display?
Did you try to set the temperature to the minimum?
Maybe the heating element is faulty....
Nov 30, 2015 | Miele Washing Machines
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
There is a bad mould build up on the inside seal of my Miele Novotronic W828, Can you help, the smell is terrible, flows through the house.
You need to wipe the seal down with vinegar. Mold needs water to grow. Have you looked at the bottom of the dishwasher after a cycle to see if you have standing water? While you are looking clean the filter.
Nov 02, 2013 | Miele Dishwashers
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
How do I check the filter on a Meile Novotronic W310
the filter is on the bottom left side in the front panel
also the drain pump is there.
Dec 24, 2009 | Miele W310 Front Load Washer
Hello, our miele w5040 is about 6 years old and we
if you mostly use lower temperature washes a bacterial mould builds up inside the machine. it can be seen as a black residue in the soap dispenser drawer and in the folds of the rubber door seal. a grey sludge also builds up on the inside of the wash drum and the drain filter. doing at least one hot wash ( above 60 C ) a week can stop this happening.
Aug 26, 2009 | Washing Machines
There is a really bad smell in my washing machine. i think it might be the rubber seal.
If burned rubber or insulation you can tell. Burning smell
Just bad odour can be from clogged filter, clean it periodically.
When not regularly cleaned and use on 30 -40 degree celsius, fungus becomes a problem. You can try cleaning the soap box and compartment with ttootbrush (old). And run the machine hot empty. When over the years fungus got everywhere, you need to disaassemble all or buy a new one. Don't try aggresive cleaners.
Also you might have a problem to the waterlock to your sewer. Check hose.
Apr 16, 2009 | Miele W310 Front Load Washer
Miele W310 Front Load Washer Logo
636 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
