I got damaged around 10 dvds even i recorded half of the disc, and can not get record later when the same dvd inserted to the recorder DVR 1600. the error message appear " unknown disc "
what is the reason ?
recording quality is excellent .
Walter Jayasinghe
Sri LankaI got damaged around 10 dvds even i recorded half of the disc, and can not get record later when the same dvd inserted to the recorder DVR 1600. the error message appear " unknown disc "
Walter Jayasinghe
Sri Lanka
You can't post conmments that contain an email address.
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible.
Another problem - if you are copying a copy-protected disc, it might not play back either.
Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Start by checking the DVR format compatibility list, see if the dvd format matches. The check DVR settings for playing features that can be adjusted. Try other DVD's that have worked on your DVR previously.
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
It sounds like you need a firmware update but it may be too late now that Cyberhome is out of business. I suggest you buy a better unit but if you have some unfinalized or unreadable discs you want to try and recover I have instructions on how to do that on a PC that may be of help.
www.drx9000repair.netfirms.com/
Walter Jayasinghe
Sri Lanka
