Question about Inverter KEB COMBIVERT F5
I have a prblem in the F5 keb combivert it's show Error E.OC & E.puci & E.Puch could you please advice us with the proper solution thanks
Sohail umer
    New Friend:
  • 4 Answers
E.puci During the initialization the power circuit could not be recognized as invalid.
E.puch power unit changed
power unit identification was changed, with a avalid power circuit this error can be reset by writting to SY.3. If the value displayed in SY.3 is written, only the power-cricuit dependent parameters are reinitialized. if any other value is written, then the default set is loaded . On some systems after writing SY.3 a power-On -Reset is necessary........
E.OC Overcurrent
Posted on Jun 08, 2013
2 Related Answers
Anonymous
SOURCE: Hi i m using keb
Hello!
What shall I do to communicate with a Combivert F5. I have tryed with different cables without success.
RPN/ Sweden
Posted on Nov 26, 2010
Anonymous
  • 332 Answers
SOURCE: F5 keb inverter problem
check you owners manual there should be inline fuses that maybe bad
Posted on Mar 10, 2010
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
Tip
E.puci error
E.puci = Power Unit Code Invalid.
When the inverter is powered up the power stage can not be identified by the control card or the power stage is the wrong type for the control card.
Typically can not be reset and unit needs to be repaired or replaced.
Contact OEM of machine or KEB for additioanl support
E OC error in F4 KEB
Error. Over Current - Peak current exceeded
Possible causes:
Motor has a short - Phase to phase or phase to ground.
Motor cable damaged/defective.
Motor cables too long.
Acceleration/deceleration ramps too short.
Damaged output phase of inverter.
EMI
Mar 05, 2014 | Inverter KEB COMBIVERT F5
Inverter keb combivert f5
What is the actual problem you are having?
Jan 31, 2014 | Inverter KEB COMBIVERT F5
Need a Way to adjust dr.2 Rated Motor Current value. Combivert F4-C
It sounds like you may have a thermal issue causing the fault trigger of the E.OC error. This coould be an issue with the motor or the inverter getting too hot. Once the system trips into error it is allowed to cool a little and you can run again for a while.
What is the actual part# and serial # of the inverter that you are having problems with?
Since they system has been running, I would not suggest aultering the voltage/hz curves in the inverter because of an E.OC error.
Dec 28, 2013 | Inverter KEB COMBIVERT F5
Oc error please help
What software are you using
Did you download the bin and language files
What cable/operator are you using
Oct 23, 2013 | Inverter KEB COMBIVERT F5
KEB 07 F5 Error code E. Puch what will cause this error and how do i clear it
E.puch means that at power up the control card did recognized the power stage as different than last time it powered up.
This is normal when the control card is changed. If the control card has not been changed, there is a problem between the power stage and the control card.
Initialize the value at sy.03 to reset the error.
Apr 25, 2013 | Inverter KEB COMBIVERT F5
Keb f5 e puch
Look under the E.puch tip section.
Feb 24, 2012 | Inverter KEB COMBIVERT F5
i have a prblem in the F5 keb combivert it's show Error
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 Logo
647 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Anon
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
