Jeep Master
- Posted on Apr 11, 2010
Re: Why is oil gage reading 60? does this mean I need...
CHECK OIL PRESSURE FIRST.DEPENDS ON THE ENGINES SIZE JEEP OIL PRESSURE RANGES FROM 25 PSI TO 37 PSI.IF PRESSURE CHECKS OUT GOOD GAUGE COULD BE FAULTY.IF OIL PRESSURE IS STILL TOO HIGH.YOUR OIL TOO THICK.OIL RETURN HOLE STOPPED UP.OIL PUMP PRESSURE REGULATOR STUCK CLOSED.
should mean 60 pounds of oil pressure. watch for it to fall at a stop and rise when accel. signifies oil pump related issue. YOU SHOULD CHECK YOUR OIL BEFORE STARTING ENGINE.!
