Question about Kitchen Ranges
I have an older stove and the kitchen timer buzzer keeps going off...at random times...i have never actually used the timer
Posted by meganhicks on
Anonymous
    New Friend:
  • 79 Answers
Un plug stove, pull cover off . if you dont use it unplug the timer wire put wire nut on it. and call it a day.
Posted on Apr 11, 2010
I have an older magic chef I am trying to use the self cleaning feature. what am I supposed to have the two timer knobs set on? Or should I say the stop and start knob and the clock?
Start time should be set to current time of day (according to the clock on the stove) and the stop time should be set for at least two hours later. This will allow the timed oven feature to work for the self clean option.
***Keep in mind that if the clock does not work you will have to shut the oven off yourself after the two hours is up!!***
Good Luck!
Jun 15, 2010 | Magic Chef 31000 Gas Kitchen Range
Code F7 appeared during oven use
You have/had a stuck keypad. If it happens again just push all pads at random to try and unstick it. If it gets to be a nuisance replace the keypad membrane.
Jan 30, 2009 | Maytag MER5530 Electric Kitchen Range
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Jan 24, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Clock on Whirlpool Stove
Check to see if the oven is set to timed bake.
Jan 22, 2009 | Whirlpool GR460 Electric Kitchen Range
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Timer buzzer
I took the top of range apart to see if I could unplug the buzzer. Wasn't sure which wire it was so I just unplugged the bottom four wires one at a time.....don't really know what it did but it stopped buzzing and all the wires are plugged back in. Only thing I can think of it must have re-set something cause it works fine now
Apr 22, 2008 | Hotpoint RB757 Electric Kitchen Range
Jenn Air Older Oven wall unit only
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Jul 08, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
215 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
