Question about Ovens
Jenn Air Range Model 88370 oven only bakes in the back and leaves food raw in the front.
Titilayo Sodipe
  • 1,428 Answers
It will be the oven element that has failed, a new one wiil need to be fitted.
It is located at the rear of the oven compartment behind a removeable cover.
I hope this helps.
Posted on Apr 11, 2010
  • Oliver Street Oct 03, 2010
    I've owned that model JennAir for 30 years and I can say that the preceeding answer is thinking of another make and model. Your symptoms indicate an oven door air leak. Check the seals and the hinges.
    If you want to check the elements anyway they're completely visible. With the lights out, set the oven to preheat 300 or so and you can see for youself if either the element in the bottom of the oven or the top of the oven fails to glow orange in a few minutes time. The bottom is the bake element, the top is the broil element..
Oliver Street
    Habit-Forming:
  • 66 Answers
The front is cool because cool air is entering the oven. At this age the most likely reason is that the oven door seal has become inflexible. Its nothing special, the same seal is used on almost every oven made by Jenn-Air / Maytag / GE / Whirlpool. it's a woven fiberglass cover on a hollow silicone tube core with a figure 8 cross section. The parts list part is 715368, but it will be discontinued and only found at an inflated price, The seal isn't a molded shape just a length of material, so an "exact fit' part isn't required just one that's long enough. You cutting it to length anyway. The seal for a General Electric WB4K1, for example, is identical material, longer than required and usually attractively priced. (The same seal costs more if the model it's used on is a higher price, model.)
To change the seal, begin by opening the oven door to the slightly open broil venting position. Place 2 screwdriver handles, door stops 1" square sticks, ... whatever to prevent the hinge springs from closing when the door is lifted off. Pull the door off the hinges, that project 6" up into the door at the bottom. Place the door handle side up on some padding, pieces of cardboard will do. Remove the screws around the edge of the door and the band that holds the inner door to the outer door, Carefully place the handle and glass handle side up on another piece of cardboard or other padding. Remove the screws holding the oven panel to the rest of the door, Replace the seal and re-assemble. NB: the seal comes in from the hidden space goers around and overlaps itself for a short distance at the bottom before disappearing again. An old seal with enough baked on drippings can look like it was a molded something or other and the parts list diagram suggests something like that. The original seal was installed just this way,
It's also possible a hinge is broken, in which case you need to replace the broken hinge. I didn't focus on that because people usually notice a broken hinge and connect the door not closing with the oven not cooking properly. The only hidden hinge issue is when the screw at the top of a replacement hinge that set the oven door position isn't adjusted correctly and the door is misaligned. It's usually kind of obvious but some people can look at a crooked door and it looks OK until they look to see if it's crooked.
Posted on Jul 19, 2019
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Instructions to replace Jenn Air oven thermostat
To remove the control panel, open the oven door wide as possible. Remove the screws from the top of the CP and the screws from the bottom of the CP. Grasp the CP bu placing hands on the right and left sides of the panel, pull out and down to disengage. Depending on manufacture run you might need to lift up and out to diengage.
Have a cloth on the oven rack to lay the control on so you won't scratch the pretty facing. Once that is done you have easy access. Wear some rubber gloves doctor, this prevents harm to the electronics. Static discharge is a no no around expensive electronics. You can do this. Take your time. Piece of cake.
You will be able to check high limit cooling fan door latch and motors 9if applicable on your model) cool ain't it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2010 | Ovens
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Feb 16, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you an Oven Expert? Answer questions, earn points and help others
