Question about HP iPAQ RX3115 Pocket PC
When my battery goes dead I lose all the programs that I installed. It crashes!
Posted by darlclemons on
Anonymous
    New Friend:
  • 168 Answers
Change ur battery and always charge ur cell by turnin it off at nights
Posted on Apr 11, 2010
1helpful
3answers
Could my remote on key fob for car battery fail to open all doors apart from drivers had it to auto garage he said ineed new locks?
Usually takes two clicks to open all doors, right? Is there no sound on the second click? If not, I would suspect the receiver--not the locks.
2answers
Lyric t5 thermostat what happens when battery goes dead
Do you have a wire landed on the C terminal? If you do then your batteries are not required. In fact, if you are not running a schedule I would take them out. If you have a (c) wire it gets power from the unit, batteries are only backup so you don't lose the program you entered. The tstat does have internal memory for when there is no power and the batteries are dead, but I am not sure how long that works.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
My nokia express music is dead battery seems to be
go to the nearest cellshop..
your phone might have a crashed program
2answers
This is my second touch pro 2, each has had the same problem. The battery goes dead, then the phone freezes and now the batter goes dead after 3 hours unhooked from a power source. I am locking the...
The batteries in those devices are Li-Ion battery (look it up on wikipedia, if you want chemical details). They are VERY sensitive to deep discharging.
They are composed of several cells - and even one deep-discharge can fry at least one. In that case, polarity in this particular cell drops and can even be reversed, rendering the battery useless.
That is why all phones switch themselves off way before that occurs - in theory. If the phone hangs, it cannot switch itself off and abovesaid happens.
So what you can do: First, get a new battery. Yours is bad. They are not expensive at amazon or similar.
Then, either
a) Prevent freezes. HTC Touch Pro 2's are not know to freeze out of blue sky (and mine rarely did), so I guess you keep on using an application that crashes you device. I suggest installing your apps one by one to see, which causes the crash. Meanwhile, rely on b).
or
b) Prevent deep-discharging. Keep it charged above 50% all the time until you are sure to get no more crashes. It will not hurt the battery to be charged often and only marginally to have that much capacity constantly.
1helpful
2answers
Battery went dead,charged it back up now it won't stay running and a red light with a key comes on
if the battery goes stone dead on these vehicles, your anti theft module (SKIS module) loses its programming. unfortunately, the only way to fix this is to have the vehicle towed to the dealer an reprogrammed. call your local dealer and consult them on their particular procedures. good luck!
2answers
Pls help me...my antivirus deleted files on my windows, and when i restart my computer it won't function properly anymore,,is it possible to reinstall windows w/o losing my programs?
Yes it is. You can reinstall Windows without losing any programs.
Insert Windows XP CD in CD Drive-->Restart Compute--> While compoter will boot up, it will ask to "Press any key to boot from CD ROM"-->Press Enter-->Then Windows Installation will start-->Installation processure will get stop at one momenet when you it will ask you to select serveral option i.e. Press "R" to Repair from Recovery console, Press "c" to continue-->Press "Q" to Quite-->Press "C" here to coninue--> Then after it will goes to next screeen and again ask you to select sereral option--> Here press "R" to repair windows and it will start repairing windows-->It will restart computer several time, here please do not press any key of keyboard otherwise installation process will be restarted again.
1helpful
Dashboard immobiliser light flashes. car tries to start but doesn
you cant if it has the emobilizer on you would have to know the resister number to install a resister chances are its already gone. there be a reprogram you can do to get it going sometimes when the battery goes dead the bcm will lose some of its programing . hope this helps Tunderboltz.
2helpful
New Generac Generator--Battery Goes Dead
Yes,if its working correctly,you should be getting a reading about 2.5 to 3 volts above the battery voltage rating while its in standby mode.
Laptop crashes (G4) often and boots up to an error message stating the date is before 2001. The date reverts back to 12/31/1969. Programs are out of wack as a result.
sounds like you have a power problem. Can your computer run on the battery? If you run it on the battery and pick it up and jiggle it, does it turn off. The reason the date is reverting to 1969 is because once the computer loses all it's power (battery and cord), it loses all information that requires power, which includes the date. I'm guessing that your power cord requires some tweaking to get it to turn on properly (light up) and that the battery is close to dead or doesn't have a great connection so it sometimes loses contact and your computer just clicks off.
1helpful
4answers
Toyota radio code
Johnny5486:
Emissionwiz is correct, but, his information is for older Model Camrys.
The 2003 "factory-installed" radios in the Camry product line does not have an anti-theft feature, and, because of having no anti-theft feature, there is no reactivation code. If you have a dead battery, the only thing you will lose regarding the radio functions would be the radio stations that you programmed into the memory. The radio will function properly after a dead battery is replaced with no issues.
HP iPAQ RX3115 Pocket PC Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
