Question about Danco Faucet Cartridge
Danco Hot/Cold Stem installation instructions Need help with the assembly
  • 5 more comments
  • Anonymous Apr 10, 2010
    There are no installation instructions for Danco.. I have a Danco 17312B Hot/Cold Stem 3Z-6H/C for valley. It has a little white plastic pc + spring+ black plastic pc + stem .... I need the sequence for assembly ... I need help
  • Anonymous Apr 11, 2010
    Shower facucet.. I'm trying to install a danco Hot/Cold Stem 3Z-6H/C stock#17312B. It comes with a tiny white plastic pc, spring, small black plastic and the Stem. no assembly instructions. I'm looking for the correct sequence that the parts are put together. Please help and don't direct me to a site like the other guy, because this item was not there. Please help. Thanks,
    Matt
    Thank You , very much appreciated and easy to understand.
    Thanks again, Matt
    Now I'm just having a problem putting the cover plate back on.. talk about tight I got one on can't get the other on.
  • mimiten Jul 09, 2013
    mimiten I'm trying to install a danco 3G-3C cold stem for Price Pfister
    I need help with installation
  • Ralph Galloway
    Ralph Galloway Aug 06, 2018
    Tried pulling and prying and no good.
  • Ralph Galloway
    Remove stuck prerless laurtory faucet. tried pulling and prying and no good, help
taran_2005
  • 10,515 Answers
The spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of taking off.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 11, 2010
  • Chase Fonteno
    Chase Fonteno Feb 08, 2014
    Well - with more detail. First you insert the little white plastic tip into the spring. Then insert the spring with the white tip facing out. Then the black rubber fitting, pushing it into place until it is snug. Then the faucet with the half moon on the back, on top, pushing it to align up with the slots, but you will not be able to push all the way into the slots, just align them. Then slip on the brass ring and screw it down, which will press the notches into their slots. Done
Oyelade Gbenga
  • 713 Answers
Hi,you can get a detailed desciption on the assembly and the disassembly,and also the installation of your danco hot/cold stem in the service manual of you device,which you can get for free at www.manualsonline.com or www.applianceproparts.com
Thanks and take care
Posted on Apr 10, 2010
I installed stem and the valve will not shut cold water off that is running
If your having major issues, I would try to locate the main on/off valves at your water heater and pump/cold water line in the basement. One the water is shut off, I would try to check if there is a proper seal...as required concerning the stem. It's probably on of the old gaskets that was not remove and doubled up. Happened to me. Good luck!
www.youtube.com/watch?v=kM-TxozD-b4
Mar 01, 2015 | Danco Faucet Stem
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
Have a shower only no tub. replaced both the hot and cold stems because shower was dripping and water pressure was low. Thought if I replaced the water pressure would return. Tightened the top nut before...
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Apr 12, 2011 | Danco Faucet Stem
I bought a 3h-10h/c but it only works for hot. do you have the same product for the cold side?
The same part works for both Hot & Cold sides. Usually preset to work on Hot (counter clockwise on, clockwise off). To set for Cold, simple remove the plastic clip from the top, slide the ring tab off, flip it over and put back on (you can only put it on one way since there's a flat "key" in it matching the stem) Now its set for Cold (CCW of, CW on). HTH
Aug 05, 2010 | Danco Faucet Stem
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Jul 18, 2010 | Danco Faucet Stem
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
How does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Apr 08, 2009 | Danco Faucet Stem
Danco Faucet Cartridge  Logo
8,760 people viewed this question
Top Danco Home Experts
Bill Johnson
mehan
Level 1 Expert
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
