Try using MP3 player or audio sources (cd) to feed the monitor to see if you get the sound OK to narrow down the problem to either Monitor or PC sound problem.
Go to the control panel and check device manger. Look for sound device and see if there is an X or ?. X means disabled. ? means driver issue.
Note: make sure your speakers are work or try to connect your head phone to the green female input in the back of the pc or look for a head phone symbol
What type of laptop HP , ASUS , COMPAQ , ACER ?.......... Up the
Volume on My HP Laptop
Open the "Start" menu and click on the
"Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either
"Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the
slider.
If you need to decrease the volume, simply move the slider
bar down.
Click on "OK" when finished and close the
"Control Panel" window.
Click on the speaker icon in the bottom-right corner of the
screen for a faster volume adjustment. Simply move the slider bar up to
increase the volume and move it back down to decrease the volume.
Volume on an Acer
Laptop
Acer laptops are typically sold with
pre-installed Windows operating systems that offer sound-adjustment features
for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem
with external speakers or headphones to increase the volume, as well as mute
all sound on the laptop.
If the computer should output an unusually low volume,
fixing the problem may be no more involved than sliding a control switch with
the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner
to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to
drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control
to open another window with volume controls for "Speakers" and
"Applications," adjusting each slide control upward to increase the
volume.
Be sure the speaker icon below each control is not
accidentally muted.
Click once on each speaker icon to remove the red circle
with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the
lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select
"Adjust Sounds" from the Hardware and Sounds category.
Hi , down on the very right side of your task bar is a icon of a speaker , click on that and it will allow you to adjust the sound level............let me know if this works ,,,,,,,,,,,,,Roy
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustmentsthere click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar hope this helps
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustmentsthere click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar hope this helps
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers hope this helps
have you tried changing the sounds on your computer if there on 100% then try goig to the menu on your moniter to see if the volume is on 100% if there both are seems like the speakers are broke
check if the monitor speakers are the default speakers for ur computer.. to do so..
click Start.. then under start search type.. Sound.. and hit enter
on this screen u shall be able to see various devices as speakers..
the one with Green check is the default speaker..
select Monitor and select Default below and thts it.. ur done..
for more info.. go to the following link from HP
http://tinyurl.com/2fvjh7l let me know if this was helpful to u.. regards,guru
Hello there:
if the volume controle is not on the taskbar try to go under controle panel and go to sounds and the adjustments for the speakers will be there. than click on add to taskbar and click apply when finished ok?
best regards mike
