Digital Concepts (1358W) 0.5x Lens Converter Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I downloaded the pictures from my memory card to my Mac computer with the Digital Concepts Converter Drive. Model# CD-35. I don't know how to erase them from the memory card now that they are downloaded into my Mac computer.
wayne walker
Level 3:
  • Master 779 Answers
  • Posted on Apr 10, 2010
wayne walker
Master
Level 3:
Answers
779
Questions
Helped
328806
Points
2177
What the make and exact model of your camera , i can find an online manual You will be able to delete all the images from the card - by using a menu item on the camera - or reformat the memory card in the camera - again another menu choice
1helpful
Need a CD Installer for Panasonic Camera
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
I have a new comptuer. We have a Samsung Digimax 420 camera We don't have the CD to install the program Is there a free download or another way to get the program installed on our new computer
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery on Windows.
Where can i download cd software for samsungs73 i moved & have lost original setup cd & have not used this camera before
You don't need any additional software to use the camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery on a Windows machine or iPhoto on a Mac.
18helpful
7answers
How do I recover pictures from the camera's memory if there are no pictures on the memory card?
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this digital camera recover program called asoftech photo recovery from
http://download.cnet.com/Asoftech-Photo-Recovery/3000-12511_4-10913438.html?part=dl-10913438&subj=dl&tag=button
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Cd won't open on my computer, Im on a mac mini and it says my computer doesn't support the cd
You don't need to use the Vivitar software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
6helpful
6answers
I would like to recover pictures I accidently erased from the memory card in my digital camera
you can use some camera recovery software
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
I have a Digital Concepts Digital Camera 89379-Z lost CD
You have to add a flash SD memory card for the audio to work as the internal memory without the memory card is not adequate for storing audio and video according to the manufacturer.
Deleted pictures
Does this camera store it's pictures on a memory card such as SD?
You can try this procedure:
Givens:
You have a card reader hooked to your windows machine that will read the card that was in the camera and
Your memory card is formatted in FAT or FAT32 (it probably was)
You have a Windows machine...
DO NOT TAKE ANY MORE PICTURES...
1. Download "freeundelete" from this location:
http://www.officerecovery.com/freeundelete/
2. Install the program.
3. Place memory card out of camera into computer, noting drive letter of the memory card.
4. Fire up the freeundelete software and point it at the drive letter of your memory card.
5. Recover what pictures you can.
Good luck.
Need Samsung S630 camera drivers for MacOS X
You don't need a driver.
Top Digital Concepts Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
