YOU NEED TO ADD MORE FREON TO THE UNIT. SOUNDS LIKE IT NEEDS TOPPING OFF. YOU CAN BUY R-134A FREON IN A PACKAGE WITH A HOSE AT A PARTS STORE. DON'T KNOW HOW TO CHARGE THE UNIT , NO PROBLEM. OPEN HOOD, START TRUCK,TURN A/C TO MAX WITH BOTH DOORS OPEN RUNNING AT
NORMAL SPEED, NO REVING, THEN FIND A BLACK METAL PIPE
RUNNING FROM A SILVER DEVICE CALLED AN ACCUMULATOR.
THE PIPE WILL HAVE A CONNECTOR, JUST UNSCREW THE CAP
AND PLACE FREON HOSE WITH THE CAN CONNECTED TO IT AND
SECURE THE END OVER THE PORT VALVE. OPEN FREON VALVE ON THE CAN AND PLACE UPRIGHT AND LET IT SIT. WHILE INSTALLING THE FREON, FEEL THE VENTS BY THE DOORS OR
DASH TO SEE IF THEY ARE GETTING COLDER. WHEN THE VENTS ARE COLD YOU CAN TURN THE VALVE OFF ON THE FREON CAN
AND DISCONNECT IT FROM THE FITTING AND PLACE THE CAP
BACK ON THE VALVE. THAT'S ALL THERE IS TO IT. YOU CAN ASK THE PARTS STORE CLERK WHICH PORT IS FOR CHARGING THE UNIT IF YOUR UNSURE. THEY ALSO SELL R-134A FREON WITH A
SEALANT MIXED IN WITH THE CAN JUST IN CASE YOUR UNIT MAY HAVE A LEAK IN THE SYSTEM. REMEMBER, **NO REVING** NO
MATTER WHAT ANYONE SAYS. THE SYSTEM WILL NOT CHARGE FASTER. IF YOU WANT FASTER CHARGING THEN KEEP THE CAN WARM. FREON WORKS WITH AMBIENT TEMPERATURE WHICH
MEANS WARM DAY OR CAN IS FASTER THAN A COLD DAY AND
A COLD CAN. FREON MOVES FASTER WHEN HEATED.
