Onkyo TX-DS696 receiver center channel not working
I have an Onkyo TX-DS696 receiver. The center channel does not work, nor does the center pre outs work when plunged into an external amplifier. Also, when performing a test tone procedure, again no sound from center channel. I do get a very low distorted sound from the center channel when I have the volume all the way up (may be crosstalk). Everything else is in perfect operating order. I am 99.99% positive there is not a user error, but something internally wrong. The settings are correct. Can anyone suggest anything?
Posted by downessean on
Anonymous
    New Friend:
The center setting is set to small. I have read the manual twice. The dialog when the volume is at a maximum level is noisy, but can still make out the dialog, no crackling, heaving hissing. (note only the center speaker is plugged in, and all other speakers are left disconnected so that I can only analyze the behavior of the center channel output). I am trying to narrow the issue down to a bad relay or more than likely a burned out transistor(s) or a capacitor.
Posted on Apr 10, 2010
Anonymous
  • 8,546 Answers
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
My display wont work and my remote quit at the same time
for this problem please call to your manufacturer customer suppport for technician to rectify thre problem because it is the internal problem so i advise do not open the cabinet of your channel receiver
1helpful
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
1helpful
2answers
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
Onkyo tx-SR605 - how do I use as a processor and
IF and only if, your receiver has connections labeled as "pre-out" can it be connected to an external amplifier.
If it does, then you connect from the left and right channels from the receiver, to the left and right channel on the amplifier.
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Central chanel no works
Hi on Onkyo receivers you must go into the speaker setup and select YES for center channel, I've on occasion turned a setting to no when I wasn't paying attention.
If that doesn't work check to see if your unit has PRE inputs and outputs
if so there should be a jumper pin that connects the two.
1helpful
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Open Questions:
0answers
My Cyber Acoustics set of stereo speakers plugged into my MAC MINI suddenly is not found in my system preferences on my MAC MINI Model # CA-2022R (I think). My Cyber Acoustics set of stereo speakers plugged into my MAC MINI suddenly is not found in my system preferences. I just recently updated my MAC's software to MAC's new Monterey 12.0.1. Apparently or at least seemingly, my speakers, although on, won't put out any sound now. My computer is no longer acknowledging their hooked up presence. Through hit and miss, I was at least able to turn on my MAC's own built in speaker. It sounds awful compared to the high quality sound of these speakers. Apple support has no idea WHY my computer has stopped acknowledging the presence and still plugged in and switched on. The blue power light is on. CYBER ACOUSTICS set of 2 stereo speakers. Is there hardware / software that I can download back into my computer that will reactivate my 2 speakers? I DON'T KNOW THEIR MODEL NUMBER FOR SURE but I think I saw CA-2022R. I have already tried unplugging them and then plugging them back in repeatedly but that doesn't help. I even re-updated my computers software for the second time with the same new Monterey operating system 12.0.1. I have no idea what else to do and Apple support is clueless. My MAC simply no longer knows that I have a set of Cyber Acoustics plugged into it. PLEASE HELP ME GET THIS TO FUNCTION AGAIN. I even momentarily plugged your speaker's green plug in into the head phone jack on my iPhone and it worked perfectly and sounded great as usual. Then I plugged it back into the back speaker input on my MAC MINI.
Ekse
 Grubhead
Grubhead
