Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher does not drain completely
Our Frigidaire dishwasher is 11 years old. Up to now it worked perfectly, but at the last use it did not shut off at the usual spot, it just quit a bit before. When I looked, the dishes were clean, but there was water at the bottom that didn't drain out. There was no dirt visible in the glass trap and the overfill protector seems to work normally.
Posted by jsuehiro on
Ambari
  • 901 Answers
Check your main drain system where your finally connect to let off the dish washer water.
Posted on Apr 12, 2010
My 4 year old frididaire dishwasher does not
Check the drain plug for some blockage ( small sock or lint.
Make sure it leans slightly back and not forward by adjusting front leg wheels.
Please rate my help++++Thanks for using FIXYA
May 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
117 people viewed this question
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
